extended cranking........blah.....
4g63mightymax
211
3
Oct 2, 2002
Townsend, Massachusetts
Ok, so i have a 91 4g63 turbo engine in a truck, and it has a serious extended cranking problem. It takes FOREVER to start, almost like it has no fuel pressure. My fuel pressure gauge reads normal, but i did just get this engine running correctly this weekend. Are there any common problems that cause hard starting ? Im looking for an easy fix before i start pulling injectors, sensors, and all that garbage out........
thanks in advance
jeremy
on the coolant neck, there are a few sensors, if the black one with two prongs (one is sideways) breaks it will not detect cold starts and make you crank forever.....
