beeztsi
- 41
- Jul 21, 2002
well this is the 2.0 forum but i figured i should post a question on a 2.4
my friend is starting/ thinking about the 2.4 build up since his car is to damn slow (12.1 on hrc 20g) .......... he just recently bought a t66 and was thinking of ways to take full advantage of that size of a turbo.
my question is ive heard the redline on a 2.4 stroker not 2.4 hybrid?? ive been hearing 6500 and is there a way you can increase the ability for the engine to take higher rpms
If the valvetrain can do its part, then you have to consider the capabilities of the rotating assembly (crank, rods, wristpins, pistons, etc.). You get into pistons speed, piston acceleration near TDC, piston jerk, side loading on the piston/rods, etc. You don't want to shock the combustion charge too hard or it may lead to detonation quickly, nor do you want to have extreme side loading on the rods. You can figure all this out mathematically w/ rod ratios, strengths of materials, etc. or you could just assume that Mitsu knew what they were doing from the factory. If the stock 4G63 redlines at 7K and you can twist 8K no problem, then I'd stick with that on a stock motor or somewhere between the two. The longer stroke on the 4G64 gets into that side loading, etc. I mentioned above so the redline is lower; say 7K to be safe. The stroker motor uses the '64 crank, stock rods, and different pistons (one configuration anyway) and it's safe to say 7K is the top redline. Maybe 6.5K even. The '64 is the same beast. The deck height is higher, so no need for different pistons. Redline should be the same as the stroker.
I know) 500whp on just gasoline, there are much better options in the hybrid/bolt on category. Why would you want something that doesn't spool til 6k?
