apexi turbo timer problem
maxgtr96
Oct 2, 2002
i have the apexi turbo timer and im having a problem with it. when i shut the car off it wont stay on. it was working fine for two months now all the sudden it wont stayy on when i shut the car off. i checked all the wiring just wondering if anyone had this problem before. any help would be appreicated thanks.
yes the ebrake is up when i shut the car off. when i shut the car off the timer shuts off to is there any internal setting. that would make it not stay on?
yes - you can shut the "timer" part off - as you can any of the other functions ( volt - o2 - a/f ) from memory, start the car, pull up on the e-brake (verify the brake light is on to be sure your switch is working ) with that 4wy switch navigate down to the timer function then move it either to the left or right i cant remmeber
