Stock Psi?
Capt.Morgan
35
Aug 28, 2002
What is the stock psi on a 1g talon tsi?
I know a kid who is running 20 psi on his, what would you guys estimate his horsepower is at?
not positive on the stock psi.. I do believe its 10-12 but not positive..
as for the kid running 20lbs of boost.. thats only part of the equation.. his mods list + tuning makes up the difference.
To be nitpicky the stock boost on a 1G is 11.1 PSI. As far as his HP, that depends on so many factors, I really couldn't venture a guess.
Originally posted by XTurboSpYderX
can anyone be "nitpickey" on the 2G stock PSI?
We need someone with a totally stock car to put a boost gauge on because you will hear something different from everyone. I talked to Mitsu service dept and they said the 1G is 11 and the 2G is 8.5. I talked to Road Race and they said that it is 14. I talked to Dynamic Autosport and they said it was 17. I dont know who knows what is going on, but I am putting a boost gauge on before i put on my B/C so I might be able to have an answer pretty soon here....i will keep you posted.:thumb:
I was always told stock boost on a 1G was 10.5 when I installed my boost gauge it read 10 pounds.... when I put on my 16G it still read 10 PSI.... and if it's 20 PSI with no other mods he won't be running much longer. however it basically depends on his mod list.
bone stock turbo 2.0 of any cars are 12-14 lbs/ft max. even the celica alltrac turbos. but the celica gt-4/rc is 17lbs/ft. max w/ 245hp @crank (stock). dont this site have any kind of stock specifications listed here like the toyo alltrac sites? this isn't much a tunersite if they dont have this info!!!!!!!!!
If you do not know the stock level then do not post it. Misinformation is a *****. Stock level is 11.x, very close to 12 on a 2g.
thank you very much sir.... I was wating for someone to scan a tech manual and post it or somthing... all I have gotten previously was "somewhere between 9 and 15... I think..." :)
bone stock on mine with an autometer sportcomp showed 9 psi in first and 11 psi in the other 4.
The first mod i did was a boost gauge, and my boost was at 11psi.When i got my hallman mbc,with it back almost out ,my boost was at 10psi.I guess the BCS has it set at 11psi,weird i thought.
Stock 97 GS-T
approx. 74,500 miles
Autometer 30-0-30 Vac/Boost Gauge
3rd Gear
12lbs of Boost
Stock 97 GS-T
3rd Gear
12lbs of Boost
