Installing Guages - HELP!!!
Rice Burner
94
16
Mar 28, 2002
Katy, Texas
Hey everyone...I just got a A/F, Boost, and Voltage guages (Autometer)and plan to hook them up this weekend. I have found some info in the VFAQ guide on the boost install, but none on the A/F and the Voltage guages.
My question is where do I hook the A/F to. I know it reads off of the 02 sensor, but where is the best place to tap into that??
As for the Voltage guage connection where would/have you all made that connection????
Thanks for the help in advance!! :D
hey,
screw tapping into a wire by the ecu. on the passenger side under the kick panel there is a little white plug with a single wire going into it. it is a female plug and has a blue wire (i think) going into it. it is taped to the main wiring harness and is the easiest wire to tap into for your a/f guage. ill look for the site where i got the info from, and post it.
yeah the plug under the pasanger side kick panel work fine for me. that plug is actually the spot where they check diagnostics for the O2. ive tried both ecu ppin and the plug. they work fine but the plug is alot easier. :D
