Downpipe install
Abraham39
Oct 30, 2004
Milwaukee, Wisconsin
Hi, i just received my punishment racing 2.5" downpipe in the mail and i noticed it doesn't come with any gaskets, I've already got a 2.5 high flow cat, and a 2.5 cat-back, so I'm trying to figure out what exhaust gaskets i need to connect my downpipe from my 02 housing to my cat? I'm just thinking two 2.5" gaskets? Any info would be greatly appreciated.
Thanks,
-Marty
Bump.... Please anyone? *shrug* Oh i measured the DP and its a 2.5 inlet and outlet
Thanks,
-Marty
Bring it to your local Autozone or whatever and ask them to find a gasket for it. You should bring it in with you to make it easier. They'll be nicer if you show up when it's not busy there. Normally something off a Ford V8 or something will fit. Just has to be 2.5" with somewhat-similar bolt holes. As long as the bolt holes are close, you can always cut or drill them bigger to make it fit easier.
I'll assume your cat already has a flange on it, so just get two gaskets. Otherwise, you could chop the flange off the the dp and connect it to the cat with a stainless band clamp from NAPA.
