spyderturbo007
DSM Wiseman
- 2,423
- 61
- Dec 20, 2002
New Cumberland,
Pennsylvania
I am planning on putting some money into the Spyder. My current mods are 2.5" DP, 2.5" Hi-Flow Cat, SAFC-II, Pocketlogger, 1g BOV, Home Depot MBC, Slotted/Dimpled Rotors and Ceramic Pads. My initial idea was to have SBR install a EVO III 16g, 550cc injectors and a 190lph FP. This will run about $2000 with tax and dyno tuning.
I am starting to wonder if this is the right way for me to go. I still have the SMIC and fear that I will have a problem with high intake charge temps. If I go this route I am looking into getting an UICP & WI kit down the road, but will have to take it back for more dyno tuning.
As you can see, I still have the stock cat back....and NO, I am NOT going to upgrade the cat back. I do not want the car any louder than it is now. So with that said ......
I was also considering the following: Trying to fabricate my own FMIC and having the 16g installed by SBR. The problem is that there are no good 2g DIY for FMIC piping while keeping your stock fog lights. Also WI seems so much cheaper and less of a hassle.
My goal: I would like to run low 13's high 12's on pump gas. But the more I look at different times for wrong wheel drive, it looks as though I will be lucky to break 13's.
What you you guys think?
There are so many exhaust threads on here its not even funny, you should be able to come up with a setup that'll suit your taste. I recommend getting a high flow racing Catco, its not very restrictive AT ALL. It doesnt justify NOT running a cat. I personally think 16g turbos are -anemic-, I read about people getting rid of them after they build a -tolerance- for them. I recommend buying the parts yourself and installing them. For another $910 there are SOOO many things you could do. Oh, and people run 11's FWD with slicks and big(ger) turbos.
