crankbender
- 1,840
- 11
- Apr 15, 2002
houston,
Texas
Well the day has finally come when I will be getting a new car. I have picked out a 90 tsi awd and am looking forward to the build up. I will have a digital camera available at all times when working on the car and intend to catalog everything so let me know what details you want to see.
Let me know what you would want to see on a dream car if you could do anything cause with this project that is where I am going. The engine will not be changed from stock internals tho...yeah I know don't frown I can always do that stuff when everything else is done.
First off every pipe on this car will be custom welded mandrel bends (donuts anyone?). I will be out with the mig and oxygen acetaline equip making everything exactly like I want it. If you have an idea let me know what you are thinking it may get incorperated into the car. The exhaust will be modular so when it goes to the track I can have dumps and on the street I can run a cat if I please.
Here are the parts on the list already
1g intake side of the engine.
2g exhaust manifold
HRC super 20g
FMIC
6?0 injectors
255 lph High pressure fuel pump (or equivelant)
AFPR set at 45-55 base fuel pressure
S-AFC
Hacked mas to avoid miscounts at high flow rates (probably 2g if i can get one)
Cold air intake (I plan on getting the filter element out of the engine bay completely)
battery relocation
4 spider gear center diff
ACT 2900 clutch kit
Turbo oil fill and drain mod
lightening of the car wherever I can (any ideas?)
4 bolt rear end (gonna have to find one of these too)
Shortest possible routing for the IC piping (probably 2-2.5 in ID)
Alcohol injection set for 18+ psi (with cut off switch)
EGT gauge (thinking about an analyzer)
donno about getting a CHT setup yet.
Intake temp gauge
boost gauge
AFM gauge
pocket logger
Possible dry ice/alcohol after cooler (high flow custom made)
Custom ram air to the filter (Yeah I like fog lights too but they have to go)
Of course belts, plugs, rubber, etc
New ignition cables (not manticore any ideas?)
May get an ignition booster but probably not
Exhaust designed to keep the wastegate air from rejoining the rest of the exhaust for a minimum of 12 inches.
Thats about it for the first round.
Any comments on that stuff or possibly something you think I am missing?
2g exhaust manifold
HRC super 20g
FMIC
6?0 injectors
S-AFC
battery relocation
ACT 2900 clutch kit
Intake temp gauge
boost gauge
AFM gauge
pocket logger
. So just take off as much as you need to avoid fuel cut.
. I like my Extreme SS o2 w/ 40mm Tial just fine
