Manifold
NeOzz1
210
Oct 29, 2003
Wellington, Ohio
How much different are the different manifolds? 2gPorted/evo3/SBR Cast
I cant decide what i want to go with and if a ported 2g manifold is enough i will go with that cause you can pick them up for cheap.
Would the effect be better or worst if a tubular manifold were used in place of the ones stated above? Note that the car would most likely be stock, or close to stock with a few supporting mods.
It could be worse. Taking longer to spool. Plus they cost alot more.
