2.3L stroker kit??
It uses a stock crank out of a 4g64 (2.4L) engine. It swaps directly in, and has a 100mm stroke as opposed to the stock 88mm stroke. You need different pistons with the wrist pins moved up 6mm to use this crankshaft, and there is some minor clearancing of the block that must be done.
