Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Bolt-on Tech
Bolt-on Tech Intake, exhaust, intake manifold, ignition, fuel system, cooling, etc - specific to 4G63 turbocharged DSMs.
Reply
LinkBack Thread Tools
Old 01-27-2005, 01:41 PM   #1 (permalink)
Proven Member
Region: Midwest
Classifieds Rating: (0)
Reputation: myblack98gst is an unknown
cheaper alternative to buying aeromotives FPR kit.
I just got done buying this from Jegs. it has everything including a gauge. the only thing I am going to have to find is a fitting for the return line which shouldn't be a problem at all.
Qty. Item Item Price Subtotal
2 Jeg's Alumium Weld-In ''AN'' & ''NPT'' Fittings - -6AN Male Weld Fitting
Item # 555-15262 $4.69 $9.38
2 Jeg's ''AN'' Swivel Hose End Fittings - -6 AN 90° Hose End
Item # 555-100021 $12.99 $25.98
1 Aeromotive A1000-6 Injected Bypass Regulator - A1000 -6 Injected Bypass Regulator
30 to 70 PSI
Item # 027-13109 $131.99 $131.99
1 Jeg's ''AN'' Union Adapter & Reducer Fittings - -6 AN Flare Union
Item # 555-100202 $3.69 $3.69
1 Jeg's ''AN'' Plugs and Caps - -6 AN Flare Plug
Item # 555-100302 $2.69 $2.69
1 Jeg's Pro-Flow 200 Series Braided Hose - 3-Foot Length
Item # 555-100910 $14.99 $14.99
1 Jeg's Fuel Pressure Gauge - 0-100 psi Black Face Fuel Pressure Gauge
Item # 555-41013 $19.99 $19.99
Subtotal $208.71
Handling $8.99
Delivery Area Surcharge ($1.80 per package) $1.80
Ground Delivery Charge $ .00
7.25% Delaware, OH sales tax $.00
TOTAL $219.50
best thing is I will have it tommorow or saturday...
I ordered weld on 6-an fittings because I have acces to a tig welder and want to make the rail to fit my SS feed and return lines. $5 for weld on vs. $50 for bolt ons..
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.09684205 seconds (66.30% PHP - 33.70% MySQL) with 9 queries
