Need TURBO AND INTERCOOLER HELP!!!!
ian7321
85
Jan 5, 2005
Indianapolis, Indiana
Alright, I bought my 91 TSi awd, and want to have a car that is streetable, but able to tear the hell out of the strip. The car came with a small 16g it is alright and all but this isnt enough. Also this is what came with the car. I would like to know how much hp to get to be in the 12s
SBR Small 16g ported and clipped
2.5 inch turboback(maybe this is a stupid question, but if i have a turbo back, and I just ordered a external dump O2 housing can I use this with my turboback??)
3 inch machV turbo intake
ACT 2600 clutch
walboro 190lph
I would like to know what would be a good set up to run in the mid 12's and still be streetable. And also do this in the cheapest way possible. I was thinking first get a evo3 16g or a 20g, front mount, bigger fuel pump(a 240lph), some injectors not sure which size to get, Joe P MBC, Apexi AFC2, Datalogger, and not sure what else, please help mE!!!!!!!!
o ya would a 4bolt rearend be a good upgrade from my 3bolt?
would that be with using the small 16g ported and clipped? Or would I need to upgrade?
hmm..the easy streetable mid 12's route:
-EvoIII, 550cc's, S-afc2, datalogger, mbc at around 18+psi, FMIC...Do some porting on the manifold(look into 2g mani's also), 02 and the new turbo's housing...
-You could re-wire the 190lph and you should have no problem
-Low 12's on the EvoIII: ^^^^ + 650cc's, 255lph/AFPR, DSMLink
