AlexP
- May 8, 2002
A buddy of mine told me that I can remove the vaccum hose off the boost controller solernoid the bottom one and by removing it it will add 2lbs of boost is this true? If so will this work with the BCs mod on this website by removing the plastic insert off the other side tube where you thread a screw into it to remove the plastic insert? If so these to cvould possibly add 2-4 lbs of boost together.
Please let me know if any of you have tried this...thanks
switched it back b4 it could do any harm
