rowlex
- 1,298
- 28
- Apr 12, 2003
Everett,
Washington
Hey guys, I recently installed an evoIII big16g, a 2.5" SS tubular o2 housing w/ atmos dump, and a 3" megan downpipe (and cat-back of coarse).
My only install problem was the bracket that supports the DP that is bolted to the block. It got in the way of me lining up the dp to o2 housing so I removed it. Will this have any negative side effects from this?? Should I build something to replace the one I took off? (since I was unable to bend it correctly to make use of it)
Thanks in advance guys.
