EclipseOwner95
- 704
- 10
- Oct 16, 2002
Jacksonville,
Florida
Possible WG Problem ?
This has been happening since i put my new motor in with the big16g on it into my car and i thought it was just an issue with backpressure on the stock downpipe, but when i put the 3'' on there and it still did it, it makes me wonder, my car, in first gear, will only build 10psi, also, i can make a WOT pull in 2nd 3rd or 4th gear and it will not boost above 10psi till at least 4200-4500rpm and then continue to build until it hits 20psi and levels off ( where my MBC is set at ) and im wondering if this could be some sort of problem with the WG opening prematurly, or never closing fully, it also could be my ghey boost controller, but im not sure yet, im planning on going to an external WG setup soon, but im just wonderin what you guys think... thx
Kyle
Kyle
