will this be enough
96whitetalon
117
Aug 5, 2002
ok im wanting to get the fpbig28 turbo, will the walbro fuel pump 255lph and the 650cc fuel injectors be enough fuel for this turbo and also should i get an fuel pressure regulator. if this isn't a good set up let me know what you would do.:confused:
yes, that's enough fuel and yes you should get a fuel pressure regulator, but don't get the B&M because you'll need to turn down the fuel pressure at idle.
No, but you can get a FPR from charged air or spoolin up (long waiting list) that has complete adjustability. If your not going to ever go bigger than the t28 than you should consider going with 550's....
