Robby Camero
- 101
- Oct 27, 2003
Toronto,
ON, Canada
My car wont start. It idles for a few seconds then dies. As soon as I step on the gas it dies as well. I am certain it has to do with the gm maf or translator. I have no error codes, the translator leds blink at first when turning the ignition on, and eveything else looks good as well. It just wont stay running. Base idle knob set for 680cc injectors and mode swiches all off except for 3" maf is on.
I was planning on just using my SAFC to tune and only adjusting the base setting on the translator for my 680 injectors, which I have done.
I didnt hook the rpm wire up because I was under the impression it doesnt need to be if I am not using the low, med and high settings on the translator. Could this be the reason my car wont start? Does the translator NEED to know what the engine rpm is all the time?
I have 1g v1.3 translator. Could the maf be faulty? I've been trying to search for a method to test the maf but no such luck.
