sacker00
- Mar 24, 2002
97 eclipse gs-t automatic. Ok so i put on my injen intake and upper IC pipe. Everything looks ok and then i start it up and take it for a ride. When i come to a stop at the top of the street the rpm's dip all the way down and car stutters and almost stalls. The rpm's go back up and level off a little but car still doesnt idle good. It doesnt stall so i get on the pedal and it seems to run ok till i slow down again. Do i need to get the idle/throttle adjusted? Do i have a leak somewhere? Any help would be much appreciated. Thanks guys.
sorry, just trying all possible angles. other than that, you may have a small leak somewhere.. the rad hose / silicone couplers that you are given may compress after a day or two so try and go back and retighten them.. make sure you clamp them behind the bead so they don't move. good luck!
