69_luv
- 522
- 9
- Nov 3, 2003
Jacksonville,
Florida
All my mods are almost done, and its almost time to start the beast for the first time. Couple questions though. I have asked this a couple times and nobody has been able to answer it though. I am running a Apexi RACE blow off valve, it has a larger hole than the other BOV's, with my UICP the pipe coming off is quarter inch smaller. Can I make up that half inch with a flare? The Apexi BOV that I have is 2.75" and the DEJON UICP that I have only has a 2.5, should I cut that open flange off, reweld a new one that has the same diameter? Can you have a narrowing on the BOV passage like that?
Second bit of question. I know I need to run a synthetic oil, I drained my oil a couple months ago, can I add the new synthetic after the old oil, do I have to run it a brief time, then drain it and add again?
Same goes for the transmission fluid, can I combine the fluid that was left in there with a new synthetic?
, thats like just rediclous. the bov will be fine as you are going from 2.5 to 2.75, not the other way around. just put it on.
