SPEEDY
- 614
- Apr 7, 2002
OK... I'm a little confused here guy's. I just purchased a chilton's manual "AFTER" my injector install, GO FIGURE, and it is saying to replace the insulators because they are not reusable. Now... are they referring, or talking about the little spacers in between the intake manifold and the injectors, or what? Because... I reused my original spacer's when I installed my new RC 550's. Do you guy's think I Should have bought new spacers or insulators if indeed that is what they are referring to? Also what did some of you guy's use to lubricate the little O rings on the injectors with? I used just a "LITTLE" dab of clean motor oil on mine, which is exactly what the chilton's manual says. I just want to make sure I did this install correctly. Thanks!!!!
