Blog Title: '97 TSi AWD Auto 2.4 Build Project
Project log following my 2.4 build.
2 Cometic Head Gaskets Fail the Same Way
As the title implies I just finished removing my 2nd Cometic gasket after it started to pressurize the coolant system.
The first failure happened at relatively low boost (24-25psi) and conservative timing for E100 (14* total, 7-8* @ 5000).
Both the head/deck were prepped for MLS to a mirror finish. The block deck was checked for flatness. I am using A1 H11 studs torqued to 95 ft/lbs (30-60-95).
The first gasket was a Cometic 87mm (.066" thick), the second gasket was 87.5mm (also .066" thick). Copper spray was used on both.
The first time it failed it was mostly at the back of cylinder #2, right in the middle. After cleaning the deck surface it also leaked in the front of #2 and the front/back of #3. Each point of failure was directly in the middle and directly in line across the cylinder (front to back).
Upon the first disassembly there was some overhang of the gasket into the chamber due to too much material being taken off when deshrouding the valves. The head was welded up, seats replaced, and re-machined.
It failed at the same boost/timing on the 2nd gasket. It held fine at 22psi. It failed in the same spots as well.
I will post up a solution when I find one, hopefully the third time will be a charm.
Total Comments 7
Comments
Posted 08-09-2011 at 09:02 AM by 95talongirl
Posted 08-09-2011 at 10:23 AM by Djsniperwolf
Posted 08-09-2011 at 02:00 PM by 95talongirl
Posted 08-09-2011 at 02:05 PM by VETDRMS
Posted 08-09-2011 at 03:57 PM by Djsniperwolf
Posted 08-10-2011 at 12:32 AM by ed1380
I installed my Cometic with copper spray, the head was rebuilt from SBR stage 2 and the surface was very smooth. Mirror finish but you could still barely see some milling swirl marks. Block I used the plastic yellow M3 prep wheel on the air dremel to clean. I was getting what appeared to be liquid in the cylinder 2 and 3. I retorqued it and it went away. I have been driving it on 27Psi for about 6 months now and no signs of a leak yet. The cooland is always full when I pull the radiator cap and check. No coolant in the oil and no smoke out the tail pipe.Posted 08-11-2011 at 09:52 AM by BIGBLAZE79
