Login
Go Back   DSMtuners > DSM Forums > Blogs > DSM_PWR
Blog Title: DSM_PWR
Rate this Entry
DSM_BOYs 800awhp/AWD Conversion Part 7
Submit "DSM_BOYs 800awhp/AWD Conversion Part 7" to Digg Submit "DSM_BOYs 800awhp/AWD Conversion Part 7" to del.icio.us Submit "DSM_BOYs 800awhp/AWD Conversion Part 7" to StumbleUpon Submit "DSM_BOYs 800awhp/AWD Conversion Part 7" to Google
Posted 10-26-2009 at 01:37 PM by DSM_PWR
Crank Install
Starting with the Main Bearings to the block, with plenty of assembly lube
Carefully set the crank onto the bearings and give it a few spins around just to make sure it spins freely..
At this point I like to check the clearances using Plastigage's
Rest of the Main Bearings on to the Main Caps and lube up the top…
Installed along with the Kiggly Girdle
I also like checking the Crank Endplay by using a Magnet and Dial Indicator.
Using a lever to push the Crank, The endplay was right at .0025 (Perfect)
Finally I removed the Main caps and checked the plastigage's, right at .003 (Perfect)
Piston/Rods Install
Using the Piston Ring Compressor, I wrapped it around the piston and tightened it down.
Used a towel and Hammer to press down the Piston into the bore
Lined up the Rod to the crank journal and torqued down the ARP bolts to 40ft lbs w/Moly Lube
Finished Product, giving it a few spins to make sure nothing hits and spins freely
Posted in Uncategorized
Views 1154 Comments 15
« Prev     Main     Next »
Total Comments 15
Comments
  1. Old Comment
    Sexy!
    permalink
    Posted 10-26-2009 at 08:23 PM by juanpac0 juanpac0 is offline
  2. Old Comment
    Nice work man....Good luck on the build!!!!
    permalink
    Posted 10-26-2009 at 09:57 PM by Khadaw66 Khadaw66 is offline
  3. Old Comment
    hpexperts's Avatar
    brings back memory's!!!! nice work
    permalink
    Posted 10-26-2009 at 10:24 PM by hpexperts hpexperts is offline
  4. Old Comment
    Great build! The only thing i wonder about is, you checked your bearing clearance with the plastigage after you had already put the lube on. Whouldnt the lube throw it off slightly?
    permalink
    Posted 10-27-2009 at 09:26 AM by snailspool snailspool is online now
  5. Old Comment
    20psimitsu's Avatar
    Coming together nice! So when is it gonna be done?
    Patrick
    permalink
    Posted 10-27-2009 at 09:47 AM by 20psimitsu 20psimitsu is offline
  6. Old Comment
    meliketoball's Avatar
    Hope you put the money I paid for your old trans in good use!
    permalink
    Posted 10-27-2009 at 10:49 AM by meliketoball meliketoball is offline
  7. Old Comment
    DSM_PWR's Avatar
    Quote:
    No, it wont efffect it, in the past ive checked without lube and the results were the same
    Quote:
    Patrick
    Thnx, im no longer sure when it will be finished, but shouldn be too long
    Quote:
    lol every pennie! So how did the trannie workout for you?
    permalink
    Posted 10-27-2009 at 04:05 PM by DSM_PWR DSM_PWR is offline
  8. Old Comment
    wow nice
    permalink
    Posted 10-27-2009 at 07:27 PM by erickp86 erickp86 is offline
  9. Old Comment
    Good to know about the lube, keep up the good work!
    permalink
    Posted 10-27-2009 at 08:48 PM by snailspool snailspool is online now
  10. Old Comment
    Build is looking great bro.....keep it up...
    permalink
    Posted 10-28-2009 at 03:07 PM by pacificvibe pacificvibe is offline
  11. Old Comment
    Tranny is still up and running. Unfortunately, someone rear ended my car to a point where I can't drive it anymore. I just got another 2g. hahaah.
    permalink
    Posted 10-29-2009 at 05:41 PM by meliketoball meliketoball is offline
  12. Old Comment
    Strm Trpr's Avatar
    The piston tops look to be ceramic coated.
    Did you use Swaintech?
    Oh, and killer build by the way.
    Did you use a stretch gauge on your rod bolts, or just torque them to 40ft*lbs and hope for the best?
    permalink
    Posted 10-29-2009 at 10:22 PM by Strm Trpr Strm Trpr is offline
  13. Old Comment
    shredwin's Avatar
    Damm nice!!!!!!!!!!!!!
    permalink
    Posted 10-29-2009 at 11:42 PM by shredwin shredwin is offline
  14. Old Comment
    DSM_PWR's Avatar
    Hell no, i used TCC piston top coating
    Not sure what you mean about hoping for the best, ive built quite a few bottom ends and never had a problem with new rod bolts, i only use a stretch gauge if the rods are used.
    permalink
    Posted 10-30-2009 at 06:59 AM by DSM_PWR DSM_PWR is offline
  15. Old Comment
    400hp93talon's Avatar
    Im jealous!!!!!
    permalink
    Posted 10-31-2009 at 12:24 PM by 400hp93talon 400hp93talon is offline
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
