Login
Go Back   DSMtuners > DSM Forums > Blogs > DSM_PWR
Blog Title: DSM_PWR
Rate this Entry
DSM_BOYs 800awhp/AWD Conversion Part 6
Submit "DSM_BOYs 800awhp/AWD Conversion Part 6" to Digg Submit "DSM_BOYs 800awhp/AWD Conversion Part 6" to del.icio.us Submit "DSM_BOYs 800awhp/AWD Conversion Part 6" to StumbleUpon Submit "DSM_BOYs 800awhp/AWD Conversion Part 6" to Google
Posted 10-26-2009 at 01:34 PM by DSM_PWR
Piston / Connecting Rod
Once I’ve filed all my rings ill start installing the Pistons into the Connecting Rods…
To make things easy when inserting the C-Clips, i use the grove in the piston to press in the clip.
Use plenty of assembly lube on the wrist pin and slide it through the Piston-Connecting Rod
2nd C-Clip to lock the wrist pin into place
Done
The Piston Rings
I start with the Oil rings, I sandwich all (3) together and Install as a single ring
The Rings endgaps will go accordingly
Posted in Uncategorized
Views 405 Comments 0
« Prev     Main     Next »
Total Comments 0
Comments
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
