Blog Title: DSM_PWR
DSM_BOYs 800awhp/AWD Conversion Part 4
Posted 10-26-2009 at 01:27 PM by DSM_PWR
Also Carlos @ TCC got the subframe finished up with the Suspension Paint…
And
now.. The Beginning of the “AWD Swap”
What the undercarrage looks like now…
Until next time… she’s tucked away for Part II[
7/13/09
1st started off by finding the rear bolt that needs to be moved to the front
I cut around this square that was hiding the bolt
I bought some replacement bolts/washers that I had welded together and then to the frame..
Here’s an under shot of what needs to be cut/moved
Next was to find the front hole and throw/weld the bolt in there
Now that was left is to remove the FWD Gas tank hangers that are in the way for the AWD Rear end
A regular drill will be able to drill through the spot welds and just hammer it off..
Done! AWD Rear Subframe bolted and mocked up!
As far as the longblock goes…
And now.. The Beginning of the “AWD Swap”
7/13/09
Total Comments 0
