Blog Title: 6 Bolt '98 Eclipse 2.3L Build
Hey guys. Thanks for checking out my 6 bolt swap blog. This build has been 3 years in the making and I’m excited to get it put together. I know how you guys love seeing builds with lots of pics so I’m going to try to post up as detailed a documentation as I can. I’m hoping to use some videos to better document the build as well. I have used Spoolin98 and blcknspo0ln’s build threads as references and they were a great help. I hope I can help future members with their swaps as well. I also wanted to make this thread so all my random questions can be in one central place. Please subscribe to the thread and help me out along the way.
This is my first build so I know I will run into a lot of problems but I know with the support on this forum and with multiple service manuals I will be able to complete this build.
Details of build
Here are the details:
6 Bolt Swap in ’98 Eclipse GSX
Head:
1G Head Ported, Deburred, Deflashed, & Chamber Work Done By Me
Head was Milled Flat
Valve Job
HKS 272/272 Cams
Fidanza Adjustable Cam Gears
Custom Conical Springs With Custom Titanium Retainers
Ferrea 6000 Series Valves (1mm Over) Coated by Calico
New OEM Spring Seats
New High Viton Valve Seals from FFWD
New Ferrea Valve Guides 1mm Over
Oil Grooves in Cam Caps
New Revised Lifters
Refreshed Rockers
ARP Head Studs
OEM MLS Headgasket
Prothane Motor Mounts
Magnecore Sparkplug Wires
Block:
FFWD’s 2.3L Stroker XP-R Kit: Wiseco Pistons With Polished Valve Reliefs and Coated Top (Heat Coating) and Bottom (Oil Dispersement Coating) by Embee (.020” over), Scat Rods, Virgin 4G64 Crank with Champhered Oil Holes & Polished Journals
Clevite Rod Bearings
Clevite Main Bearings Coated by Calico
ARP Main Studs
Evo 8 Oil Squirters
Block was Deburred, Deflashed, and Painted Black by Me
Block was Milled
ACT Streetlite Flywheel
Forward Facing Oil Filter Bracket
New OEM Water Pump and Timing Components
BS Removal Kit
Transmission:
Shep Stage 4 Tranny with Evo III 1st Gear
Fidanza 4.3 Clutch and Pressure Plate Kit
SS Clutch Line
Exhaust:
DNP Tubular Exhaust Mani
Tail 38mm Wastegate .9 bar
Custom O2 eliminating downpipe
High Flow Cat
Custom Exhaust
Turbo/Fuel:
GT35R BB Turbo with .82 A/R Turbine Housing & Shroud S Compressor Housing
255 Walbro Fuel Pump with Rewire Kit
Hallman Pro RX Boost Controller
Custom Intercooler Setup with Spearco Core and Synchronic BOV
EVO 8 MAF
Hi-Flow Fuel System from FFWD with Aeromotive FPR
FIC 1050cc Injectors
Bored 1g TB
Ported 1G Intake Manifold
Electronics:
Black Top CAS
Prosport EGT, Oil Pressure, & Boost Gauges
’95 EPROM ECU
DSM Link V3
Innovative LC-1 Wideband O2 Sensor
RRE 1gina2g CAS Harness
Battery relocation
Cooling:
Spal Fan
Mishimoto Radiator
New OEM Thermostat and Housing
Head:
Valve Job
HKS 272/272 Cams
New Revised Lifters
Refreshed Rockers
ARP Head Studs
OEM MLS Headgasket
Block:
ARP Main Studs
Evo 8 Oil Squirters
Block was Milled
BS Removal Kit
Transmission:
SS Clutch Line
Exhaust:
High Flow Cat
Custom Exhaust
Turbo/Fuel:
EVO 8 MAF
Bored 1g TB
Electronics:
Black Top CAS
’95 EPROM ECU
DSM Link V3
Battery relocation
Cooling:
Spal Fan
Mishimoto Radiator
Total Comments 7
Comments
Looks like a great, well balanced setup, should be loads of fun huh.
Posted 11-16-2009 at 02:40 AM by juanpac0
Posted 11-16-2009 at 04:09 AM by jjrock5
Posted 11-16-2009 at 09:28 AM by BigBeans
Posted 11-17-2009 at 02:32 PM by flawlessTSI
Posted 11-19-2009 at 10:41 PM by HurleyTSi
Thanks guys. I'll have pics up soon. They will be in a new blog. Just got some before pics up today. I have to resize all my pics and its a real pita. I would go divided T4 but I got a really good deal on the exhaust mani and im on a budget. Maybe in the future.Posted 11-25-2009 at 01:20 AM by Clutch GSX
Posted 01-01-2010 at 04:15 PM by Boiler2
