Blog Title: The Gold Digger
She takes my money when I'm in need
Wire Tuck, Rust Repair, 2Gb Talon Conversion, etc.
Rear Interior Is In, Wire Harness Is Out, Bumper Is Sort Of Painted
Posted 09-19-2011 at 02:50 AM by Blurred Talon
I started by dying the main hatch panel.
I also washed all the other pieces off and let them dry.
Before I put everything back in I wanted to clean up the floors, sadly my small shop vac was at home so I couldn't do the greatest job, before I do the final assembly I'll have to bring it out.
I then put the rear panels in but hit a small snag, the center trunk panel needs some trimming to sit flush with the aluminum floor. The other pieces may need to be trimmed too. I'll fix this at a later date.
I then moved on to pulling my engine and front chassis harnesses from the car. This was actually pretty easy, I labelled everything I knew but some things will need to be researched before any work starts. Once I have everything labelled I can make a plan of attack.
Chassis harness.
No wiring.
Finally I got the bumper painted but ran out of time for clear coat, doesn't look half bad for a rattle can job though.
Chassis harness.
No wiring.
Total Comments 7
Comments
Posted 09-19-2011 at 05:54 AM by Scott McIntyre
Posted 09-19-2011 at 12:58 PM by Blurred Talon
Posted 09-28-2011 at 09:02 AM by dubysnax
Posted 09-28-2011 at 11:22 AM by Blurred Talon
Posted 09-30-2011 at 05:54 AM by goodbuds
Posted 10-17-2011 at 09:03 AM by cbarr0288
Posted 10-17-2011 at 09:24 AM by Blurred Talon
