Login
Go Back   DSMtuners > DSM Forums > Blogs > The Gold Digger
Welcome to DSMtuners
Blog Title: The Gold Digger
She takes my money when I'm in need
Wire Tuck, Rust Repair, 2Gb Talon Conversion, etc.
Rate this Entry
Rust Repair Part 4
Submit "Rust Repair Part 4" to Facebook Submit "Rust Repair Part 4" to Digg Submit "Rust Repair Part 4" to del.icio.us Submit "Rust Repair Part 4" to StumbleUpon Submit "Rust Repair Part 4" to Google
Posted 04-25-2011 at 04:16 PM by Blurred Talon
After a whole day I've got the trunk 99% done (I need to weld in a small little patch) and the driver side rocker panel.
Copper weld through primer on everything.
Tacking in the driver side trunk patch.
Seam sealer and paint on the trunk patches.
Driver side rockers patched and seam sealed. I remade most of the lip for the wheel well, the small gap will be hidden by the skirt. I need to hit the wheel well with some rocker guard.
That's it for today.
Tomorrow I'm tackling the passenger side rockers. I'm nervous about welding over there so I might just pop rivet and seam seal it for now and have a pro do it later.
I also have to weld in the new front rad support.
Posted in Uncategorized
Views 2838 Comments 10
« Prev     Main     Next »
Total Comments 10
Comments
  1. Old Comment
    ziggo0's Avatar
    Just curious because this looks like what I'll be doing...what does the seam sealer do? Protect the welds? Great work man - I wish I had the stuff to start on this kinda project myself.
    permalink
    Posted 04-26-2011 at 05:45 AM by ziggo0 ziggo0 is offline
  2. Old Comment
    Blurred Talon's Avatar
    It seals the seams between body panels, keeps water and what not out.
    Sheet metal isn't continously welded, it would take too long because of the heat generated (too much heat and you wrap and burn through the metal). So everything is spot welded and then seam sealer goes on over top.
    permalink
    Posted 04-26-2011 at 07:14 AM by Blurred Talon Blurred Talon is offline
  3. Old Comment
    housegsx's Avatar
    Scrub those wheel wells out and coat them. I got Blue Magic Pure Rubber Coating from PepBoys and it worked great! It's the best stuff I've used out of a spray can.
    permalink
    Posted 04-27-2011 at 08:56 AM by housegsx housegsx is offline
  4. Old Comment
    Dsm4lyfe12's Avatar
    Actually, you spot weld because when the molecules in the metal expand and cause the metal to warp in different spots causing it to bend and making your measurements off, and ruining your whole process. Also, its easier to grind. (i would recommend a low grit tiger paw, if your going that route). So basically i just scientifically agreed with you. I give you many props! looks great.
    permalink
    Posted 05-03-2011 at 10:05 PM by Dsm4lyfe12 Dsm4lyfe12 is offline
  5. Old Comment
    ^, thanks!
    housegsx: I've got the drive side undercoated now. I used stuff from Dominion Sure Seal. I'll post pictures after class. Driver side and trunk are finished. Passenger side is 95% done.
    permalink
    Posted 05-04-2011 at 02:37 AM by Blurred Talon Blurred Talon is offline
  6. Old Comment
    dalesmitsu's Avatar
    Where can I get the seam sealer? Good welding job, can you do some welds for me.
    permalink
    Posted 05-14-2011 at 09:13 PM by dalesmitsu dalesmitsu is offline
  7. Old Comment
    what kind of welds are those? kinda looks like the wattage was down or you went pretty fast x.x
    but non the less Gratz on making your bird Clean!
    permalink
    Posted 05-17-2011 at 01:00 PM by Haytees Haytees is offline
  8. Old Comment
    Quote:
    I bought mine from a place that sells Auto Body Supplies. Try NAPA though, they usually have it. My welds suck but thanks.
    I had the wattage down on the lowest setting, plus I was using a pretty long extension cord that wasn't made for a welder so I'm sure there was some voltage drop. It's just an older Lincoln Mig Pak 10, 110V job with no gas. It's my old man's and I've used it more then him (no clue why he owns it lol).
    I'll be finishing the rust repair this weekend, I'll post more updates.
    permalink
    Posted 05-18-2011 at 05:15 AM by Blurred Talon Blurred Talon is offline
  9. Old Comment
    HaveBlue83's Avatar
    i need to do this one day on mine....I have rust spots behind my sideskirts, but not really anywhere else....I got lucky.
    permalink
    Posted 05-24-2011 at 08:50 PM by HaveBlue83 HaveBlue83 is offline
  10. Old Comment
    duy35's Avatar
    hey what gauge metal did you use for welding near the side skirts
    permalink
    Posted 03-18-2012 at 08:02 PM by duy35 duy35 is offline
DSMtuners Main Sections
DSM Forums
DSM Regional Forums
DSM Builds/Journals
DSM Articles
DSM Tech Guides
DSM Upgrade Paths
DSM Parts Reviews
DSM Vendor Reviews
DSM Classifieds
DSM Parts Guides
DSM Photos
DSM Videos
DSM Timeslips
DSM Dyno Sheets
Shirts & Apparel
DSMtuners Decals
Advertising Info
Our Sponsors
Site Rules
Terms of Service
Privacy Policy
Site FAQ
About Us
Contact Us
