Login
Go Back   DSMtuners > DSM Forums > Blogs > blcknspo0ln
Blog Title: blcknspo0ln
Rate this Entry
Part 20
Submit "Part 20" to Digg Submit "Part 20" to del.icio.us Submit "Part 20" to StumbleUpon Submit "Part 20" to Google
Posted 09-23-2008 at 11:35 PM by blcknspo0ln
Note the orientation of the shaft. The shortest end goes where the TPS will bolt to.
Spin the shaft on its side, so you can slide the plate in. DO NOT use a metal hammer on this plate. It is very soft and you can easily dent the plate and make it not seal correctly. I used a mallet for this.
Again, making sharpie notes on everything always helps.
You have to play with the plate a bit to get the holes to line up. Then just bolt her down. I used new screws and red loctite.
Here's the most PITA process of putting a TB together. Put the spring on, make sure the hook gets put on the post.
Slide the larger one over it.
Put the green spring inside the plastic casing here.
NOW STOP! Instead of fighting with pliers, needle noses, clamps, fingers, etc. Just ziptie the two top hooks together. I found out by chance today that it was by far the EASIEST way of getting these stupid coils together. Now hold the ziptie in one hand and spin the TB, while pushing down on the plastic thing. Once you get the lines you previously made with your sharpie in line (usually 2 full rotations), put the hooks onto the ear.
Final product:
Bolted her down with the TB elbow:
I rushed along and bolted this stuff fairly quickly:
UICP with new hump hose from extremepsi
battery
FP intake pipe
home made CAI
For anyone who wants to know, it's just a 4" 90* PVC pipe (painted black), 4" fernco coupler (plumbing aisle) and a 4" KN filter.
JMF cans. Conveniently enough, the visteon radiator leaves PERFECT room for the arm on the JMF coolant can.
Posted in Uncategorized
Views 160 Comments 0
« Prev     Main     Next »
Total Comments 0
Comments
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
