Login
Go Back   DSMtuners > DSM Forums > Blogs > blcknspo0ln
Blog Title: blcknspo0ln
Rate this Entry
Part 13
Submit "Part 13" to Digg Submit "Part 13" to del.icio.us Submit "Part 13" to StumbleUpon Submit "Part 13" to Google
Posted 09-23-2008 at 11:25 PM by blcknspo0ln
Oil pan is back on:
Oil return:
I won't spend too much time on the timing belt, procedure outlined here:
http://www.dsmtuners.com/forums/arti...-6bolt-2g.html
For those who don't know what gap you're measuring:
My ubercool powdercoated cam gears
I put the throttle body on. It has no FIAV with the blockoff plate from JMF and this is with an SSAC TB elbow.
I put the timing belt covers on. If anyone is wondering, those large gashes are a result of the AC tensioner slipping and causing near fatal death to my timing belt last summer. I have since cut the timing cover into two sections because it makes taking the lower cover off when the engine in the car much much easier.
Running new vacuum hose. Remember that the vacuum line going to the brake boost has a check valve in it. DO NOT FORGET!!! You cannot have positive pressure going back into your brake booster.
Tidying up and gearing for the trans and engine installation Now I just have to get the cherry picker back from my friend.
Patiently waiting...
Posted in Uncategorized
Views 63 Comments 0
« Prev     Main     Next »
Total Comments 0
Comments
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
