Blog Title: DSM Cocktail project
Firstly let me introduce myself.
My name is Leo and I live in Sofia, Bulgaria (Europe).
I have been building my car since 1997 and so far the car looks like this:
A 99 GS (euro spec - 141hp 4G63) with 97 GSX drivetrain and 91 6-bolt, 1G engine wiring harness and 1G eprom ECU.
This week I start my engine build after almost a year of gathering parts. My goals are to make it around 500 crank hp, but everything over 400 crank hp will be success. Here in Bulgaria we don't have a good gas. The best one is 100 octane which is something like your 93 octane gas.
I hope this project will be interesting for you and make you comment/help me out.
10 months later the engine gets back in the bay
Posted 12-13-2010 at 12:18 AM by AlphaVision
Tags bay, engine, install, transfer case, transmission
This sundey me and 3 of my buddies, armored with a heater, dry food and drinks went into the freezing garage to put the engine, tranny and transfer case back where they belong
A shot of the painted and polished timing covers
Finally the engine is back in
Tranny and transfer case now in place
Downflow outlet of the 68HTA. I think it will clear from the radiator fan.
When installed the front mount we got a lot frustrated - will the wastegate actuator interfere with the mount? Luckily it was 1-2 mm away from it so they will not touch...whew...
Total Comments 4
Comments
Posted 12-13-2010 at 08:34 AM by project1g
she looks good, but what is it you're wanting to know? even though 93 octane is the premium fuel in some parts of the u.s.... 100 octane is still better than the 93. that's still a hotter fire in the combustion chamber(less work on the engines rotation). people are still putting out big numbers on pump gas with their cars, but if race fuel is availible that would be best depending on your application.Posted 12-13-2010 at 05:25 PM by 19tsi91
Yeah, I guess i sneak through the process of grinding the wasgegate actuator bolt housings and converting the actuator rod to a regulated one in order to move it further from the mount bracket.Quote:
I don't plan changing the fans unless they interfere with some of the hardware there which I doubt will happen. This week will try to mock up the IC pipingPosted 12-14-2010 at 04:09 AM by AlphaVision
I can certainly buy race fuel from the local racers and performance shops, but it will be too expensive for a street driven car. I will have to learn how to mix my own fuelQuote:she looks good, but what is it you're wanting to know? even though 93 octane is the premium fuel in some parts of the u.s.... 100 octane is still better than the 93. that's still a hotter fire in the combustion chamber(less work on the engines rotation). people are still putting out big numbers on pump gas with their cars, but if race fuel is availible that would be best depending on your application.
I will dyno it using the 100 octane and post some numbers.Posted 12-14-2010 at 04:11 AM by AlphaVision
