Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech > Automatic Tranny
Automatic Tranny Automatic tranny discussions. Sponsored by Import Performance Transmissions
Reply
LinkBack Thread Tools
Old 06-27-2007, 10:55 PM   #1 (permalink)
Proven Member
Classifieds Rating: (0)
Reputation: 91vr4evolution is an unknown
Plate LSD into auto?
Hi,
I know you can't just install a plate LSD in a standard auto trans, as the auto trans fluid is not compatiable with the plates, but is it possible to install a seal around the front output shaft, perhaps where the VC normally sits (I am planning to run a welded center diff). If I was able to do this, then I could run the diff housing as a seperate housing, and use appropriate LSD oil. Is this feasible, or even practical?
I have been looking for a viscous LSD to replace the plate LSD that I do have, but I have been unable to find one.
Thanks, Mike.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.08733392 seconds (64.07% PHP - 35.93% MySQL) with 9 queries
