Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > 4G63 DSM Tech > Drivetrain Tech > Automatic Tranny
Automatic Tranny Automatic tranny discussions. Sponsored by Import Performance Transmissions
Reply
LinkBack Thread Tools
Old 04-20-2007, 05:01 PM   #1 (permalink)
Proven Member
AL92's Avatar
Classifieds Rating: (0)
Reputation: AL92 is more helpful than not
Car won't move!
Ok bought a 91 awd auto turbo. Car runs good has low mileage but has big problem. It will not move forward or reverse.It seems to go into gear in that the engine slows down a bit and it sort of makes a going into gear noise. Although I think the park pin or something is broken as well.
The car may have been towed improperly and heard that burns out something.the viscous coupling? If the viscous is burned out will that make it so it don't move when revved forward or reverse? And if so how much are these viscous couplings and how hard to install does the transmission have to be removed to install it. Or could the stall converter be messed or something also. We checked fluid and it seems the tranny has the proper levels.
Offline
[posts] Reply With Quote
Related Auctions
Sponsored Links
Old 04-29-2007, 01:41 PM   #2 (permalink)
Proven Member
theSicKness's Avatar
Region: Southeast
Classifieds Rating: (3)
Reputation: theSicKness is more helpful than not
id drain the rear diff...odds are its got broken gears.. also id check the transfer case..
Jesse
Offline
[posts] [blogs] Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.34135509 seconds (17.98% PHP - 82.02% MySQL) with 9 queries
