Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > General > Tech Article Archives > Articles: Engine & Fuel
Add to this Article
LinkBack Thread Tools
Old 12-10-2003, 09:37 AM   #1 (permalink)
Proven Member
Classifieds Rating: (1)
Reputation: 97dsmbishi is an unknown
2G-specific Radiator Installation
I did this for the first time yesterday. Fun times....not. :cry:
Supplies:
New Radiator
Ratchet w/10 mm socket
WD40
Jackstands
Bucket (For coolant/anti-freeze to drain into)
Clamping pliers
Prestone coolant/anti-freeze (I bought 3 bottles)
Water
Flat head screwdriver
New radiator hoses (Optional)
Screw-type tightening rings (Optional...but HIGHLY recommended)
Step 1: Prep work & draining radiator
Jack the car up & use jackstands! Position the bucket underneath the drain plug, twist the tap and let it drain.
Step 2: Unbolting the radiator
There are 4 (four) 10 mm bolts that hold the raditor mounts in place. Unbolt those and the radiator will slip out of the engine. Except there are 2 hoses holding it in still.
Step 3: Getting down & dirty
The first hose located by the radiator fill tank is relatively easy to get off. Grab your clamping pliers and clamp the stock clip/ring thing and slip it off (some WD40 works well here). The hose was really tight on there, so I used my flathead to pry it up a bit, a few more squirts of WD40 will do the trick.
Now the second hose (below the A/C compressor fan) is a major PITA!
Unfortunately my stock radiator popped a leak and spilt all my anti-freeze/coolant all over I-65, so by time I got home...well you can imagine. This saved me from having to jack the car up to drain it (since there was nothing left in there). I should have, but I was being lazy.
Get your pliers again & clamp the clip/ring thing. Again, this was a biatch because of the positioning. I had to take my flathead to that one also. Once you get that last one off, the radiator will slip right out.
Step 4: Unbolt A/C condensor & radiator fan
You will have to unscrew/bolt your fans. Simple enough, just do one at a time & swap over to the next core so you don't mix them up. The stock screws/bolts didn't fit the aftermarket core, but the new radiator came w/inserts that slip in. Tighten both fans and move on to the next step.
Step 5: Installing the new core
Get the new radiator & check for imperfections etc. Work backwards for your installation, the radiator has 2 plastic points at the bottom that fit into 2 mounting spots. Instead of those annoying clip/ring things, I switched to the screw type which saves you alot of time, effort & aggrevation. Once you have the 2 hoses replaced, get your radiator mounts and the 4 bolts that go with it. Tighten those & you're about 90% complete.
Step 6: Flushing/filling core
Flush your core by filling it w/70% coolant/anti-freeze (c/a)& 30% water. Replace the the c/a in your resovoir, it's probably dirty also. Run to normal operating temperature w/the HEAT on full blast. Shut car off & let cool. Unplug, drain the nasty stuff out. Plug it back up, refill with 50% c/a & 50% water. And you are done!
Enjoy!
:thumb:
Phil
Pics to follow!
Offline
Related Auctions
Sponsored Links
Old 12-12-2003, 09:03 AM   #2 (permalink)
Proven Member
Pics.
Loosen.
Offline
Old 12-12-2003, 09:06 AM   #3 (permalink)
Proven Member
Loosen#2
Offline
Old 12-12-2003, 09:11 AM   #4 (permalink)
Proven Member
Unclip this from the bottom of the radiator:
Offline
Old 12-12-2003, 09:13 AM   #5 (permalink)
Proven Member
Undo the top clip:
Offline
Old 12-12-2003, 09:20 AM   #6 (permalink)
Proven Member
You'll have to unclip the electrical connectors also:
Offline
Old 12-12-2003, 09:29 AM   #7 (permalink)
Proven Member
Pull out the core and remove fans:
Offline
Old 12-12-2003, 09:32 AM   #8 (permalink)
Proven Member
Put the new core in:
Offline
Old 12-12-2003, 09:39 AM   #9 (permalink)
Proven Member
Re-attach lower radiator hose:
Get SCREW-type rings!!!
Offline
Old 12-12-2003, 09:58 AM   #10 (permalink)
Proven Member
Flush radiator.
Drain.
Refill.
& you're done!
:thumb:
Phil
Offline
Add to this Article
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are Off
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Page generated in 0.17224312 seconds (67.73% PHP - 32.27% MySQL) with 10 queries
