Login
Go Back   DSMtuners > DSM Forums > General > Tech Article Archives > Articles: Electrical & Wiring
Reply
LinkBack Thread Tools
Old 10-23-2008, 03:36 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Proven Member
tsiAWD91x's Avatar
Tech Posts: 145
Photos: 10
Classifieds Rating: 0
Reputation: tsiAWD91x is an unknown
1G-specific 1G fuse box relocation and wire tuck
Name:  intake manni.jpg
Take all the bolts off holding this piece of plastic on their should be 3 or 4 bolts. carefully unclip all the sensors in the area after(4 fuel injectors--cam angle sensor-TPS--coil pack---transistor--thermostat housing (3) sensors be careful on these cause they are brittle also the ISC--o2 sensor--throttle plate sensor(remove the fuel rail bolts 1 by 1 to remove the Cruise control cable and get it out of you way its a pain in the ass,l tuck it back out of the way
Name:  wire bracket.jpg
here's the wire bracket off take our flat head and pry out on the tabs careful in case you want to use this piece again
here's the fire wall the harness runs along the wall with bolt brackets you can remove with zip ties holding them to it. trace it all the way down to the end (brake and clutch (manual) fluid resv.) make sure you also unplug the fuel pump box plug--cruise control plug--un bolt all the ground wires from the fire wall their should be a few--Noise condenser resistor--(i will try and get some pictures of these sensors
don't forget to unplug this sensor if you have a manual transmission its tucked away
Name:  brake bracket.jpg
here is the bracket remove this (2 bolts) it will make life a lot easier
Take and do this with your wires and start to strip all the hard wiring stock sleeves that are stiff and ZIP TIE your wires together and rap some new WIRE LOOM around them or what ever you choose-its a lot easier to remove all the stock shit cause it allows you to bend and move the wires 100% better.. plus its cleaner
here's how i did it.
Name:  fuse box harness.jpg
after you get all the wires over the side stripped and re-loomed etc. trace the harness along the side to the fuse box. you are going to need to cut some of the zip ties hold it down to the frame. unravel some of the stock wrap on the wire and expose them like so
Name:  wires splice.jpg
Cut and splice the wires and number them accordingly. i suggest soldering them one at a time so you don't get confused.. that's what i did..
Last edited by Defiant; 10-23-2008 at 11:24 PM. Reason: Tried to fix some grammar, but modern computers can only do so much.
View photos of this member's car
Advertisement
To browse the forums without the advertisements above, Login/Register
Reply
Bookmarks
Thread Tools
Similar Threads
Thread Thread Starter Forum Replies Last Post
My Fuse Box Relocation and Cleanup Project turbosax2 Project/Build Updates 0 09-24-2008 08:26 PM
Fuse Box relocation ideas syrushcw Newbie Forum 7 07-24-2008 10:12 AM
Fuse Box Relocation Questions/Opinions GSX26 Newbie Forum 8 04-18-2008 08:06 PM
fuse box for battery relocation ITSME4G63 Appearance/Interior/Exterior 5 04-09-2006 09:09 PM
Fuse box relocation *PICS* Wikkedson Appearance/Interior/Exterior 11 07-18-2005 10:04 AM
» 2010 DSM Calendars
» DSM Mechanics Gloves
» Recent Blog Entries
Seat
by: Spdfreak
Update 4
by: Kevin TSI
Engine shots
by: Spdfreak
Best DEAL ever *Update*
by: 4Motion4g63
2.4 Liter G4CS build thread
by: Atuca
» Recent Tech Threads
Title, Username, & Date
should i buy 1g or 2g?
by: mcavalear
Timing Belt Cover Issues
by: 2GeNTSi
good deal?
by: greenDSMdude
1g maft install on 2g
by: hondaslayer1
performance tie rod ends?
by: wcpierson
» Latest Gallery Photo
User Dsmj89
» Advertisement
» Current Poll
What will you be buying soon?
DSM Calendar - 34.78%
8 Votes
18 Votes
7 Votes
Total Votes: 23
You may not vote on this poll.
Powered by vBadvanced CMPS CMPS v3.2.1
DSM Forums | Pontiac Solstice/Saturn Sky Forums
© 2009 SPEEDtuners Network, LLC All Rights Reserved
Search Engine Optimization by vBSEO 3.3.1
