T-28 and Type-S Question
siceclipse
1,681
12
Jun 26, 2003
FFLD County, Connecticut
Hey guys i just installed the t-28 and i have the type-s in too.
#1: where should i have the adjustment spring? i have it backed out a little more than half way and i still get a little flutter. should i loosen more, or should i just tighten it and attatch the hose on the second nipple?
#2: What the hell is up with this turbo lag?
I know it spools a little slower than the t-25 but this is a little slower than expected. P.S. no boost leaks except a small one somewhere behind the intake manifold but its really and i mean really small.
Man-O-Man, 50 views and only one reply. Come on guys you must have an idea or a flame or something.
I set mine so that I only get the full blow off whistle sound after nearly a full throttle pull under load (as in not downhill), maybe it will whistle under an 80% throttle pull, but definitely not at anything under 10psi. Then it will only flutter. Get it to where it almost sounds like its laughing (chuckling, snickering, fluttering) at full thottle then back it off little by little until it sneezes. Have fun.
i discovered a pinhole leak somewhere behind my intake mani.
also, i dont know if this is true or not but after all the mods listed in my profile, i have not reset my battery. i havent seen enuff online to make me believe this works but if you guys think i would help ill give it a shot.
