150MPHSpyder
- 1
- Apr 1, 2004
Kissimmee,
Florida
okay i picked up a mint condition 1998 Spyder with a 2.4 NT engine in it. the car is heavy and sloooowww. Im looking to build it up a bit. not looking too run 12s at the track but more looking to be able to keep up with these high speed hondas and volkswagons that have been toasting me on the highway. im not a 1/4 mile driver im more a high speed cruiser. right now the car runs about 115MPH and it takes time to get there. so the past three days have been dedicated to reading about perfomance mods for this motor of which in the after market there seem to be none.
Heres the catch. I want 150MPH and 225HP, so how do i get there.
A turbo for me is doable but what else to start with should be done, for best performance before i bolt up a turbo. does the 4g63t dual cam head swap result in better performance ?? or should i leave the stock headon it. will it affect the performance? is there a reputable company that can port/polish flow bench for max CFM my set of intake/heads/valve/exhaust ports?? maybe over size valves ? like available for the Stealth R/T from http://www.3sxperformance.com/engine-upper.asp also of which i own one of those. what about larger fuel injectors? larger bore throttle body? exhaust ? headers? cam ? under drive pulleys ? maybe i should just ask what combinations of these mods will work together, or conflict with the turbo installation later ? or should i nail them all one by one, then add the turbo. id like to not have to re-do the bottom end. since the block only has 85K on it. and when it gets turboed im looking for less then 10lbs boost. the turbo i am looking at is from dougs dynopower, its the Eclipse 4 Cylinder Kit. now what else needs to be considered to prep for the turbo upgrade? mind you if i can make the car go 150MPH without the turbo i will, mind you im not a drag racer just a fast driver,, and yes the car is an automatic. okay guys let me have it.
ok for underdrive pulleys you can use the crank, powet steering and alternator pulleys for the 4g63T,
