98TsiAWD
DSM Wiseman
- 2,861
- 8
- May 19, 2002
94 3000GT VR-4,
North Dakota
Did you check your main bearing clearances? Because you dont show that in the pics or your posts. Are you just bolting stuff together and hoping it works? Just curious.
As far as that balance shaft elim kit you got,
The freeze plug method sucks. Mitsu makes a plug for that hole, mitsu also makes a oil pump stubby shaft that has an oil galley built into it. Does you stubby shaft have an oil galley? Would really suck to have that stubby shaft seize up on you, seizing your oil pump. bye bye motor.
