BOOSTED4LIFE90
- 105
- Aug 30, 2003
Anaheim,
California
Hey fellas! I ran into a little problem.After installing a 3'' RnR o2 housing with a Turbosmart 35mm external wastegate(15psi spring) and a 3'' downpipe my boost increased to 20+psi.So i messed with my mbc and still no luck so i noticed that the internal wastegate actuator arm was stuck open and thats what is causing my ride to boost so high.I installed everything correctly first i put a T in between the hose that runs from the blow off valve to the intake manifold and ran it to one end of the mbc and then ran the other end of the mbc to the lower nipple on the external wastegate.Secondly i plugged both nipples on the MBS i also plugged the nipple on the turbo and on the intake,did i have to plug the nipple on the internal wategate too or just leave it open?Anyways i need some help to fix it before i blow my t-25 to pieces,Yes i have a t-25 reason is because thats what i purchased the car with but plan to upgrade to a 20g in the near future,but for now will have to run my t-25,im only suppose to run 15psi by the way.Now i need your help first off can i do the job or do i have to take it to a shop?If simple i can do it i will just need some instructions on how to do it.How do i get my wastegate actuator arm to open and close correctly?Do i need to buy a new internal wastegate like the FP 17psi?Whats this 34mm flapper mod i heard somewhere?Can i do this or what do u guys reccomend?I really need some help fellas any advise would be greatly appriciated.I really need to run my car to its full potential fellas not hit 15psi and then let off gas and fear that im going to blow up my turbo. Thanks for taking the time to read this hope you guys can help.You guys have not let me down yet. Thanks and Later!
