1gDsmRacer92
- 69
- Jan 25, 2004
Memphis,
Tennessee
hey guys i got a 92 eclipse gs 5 speed, it was like this when i bought it but when i downshift, and only when downshifting, it grinds 1st and 2nd gear, i just got the car so i havent had time to do anything to the transmission but i plan to put the metal bushings under the plate and in the shifter linkage to replace the crappy rubber ones and also going to change the trans oil with bg synchro shift (should i use somthing else) and rebleed the clutch slave cylinder, my clutch is really soft with hardly any resistance so hopefully that will fix the clutch, if it doesnt what else could it be causing the clutch to be real soft, i wasnt sure if that was causing the grinding but if that were it then it would do it in every gear wouldnt it? thanks guys for your help, DSM's kick ass you just got to keep them up, i plan on buying a 92 eagle talon tsi awd with 5 speed in december i like there body style better witht he swirl side panels.
