Nighthawk01
- 128
- Aug 27, 2003
Hi, i recently bought a 91 talon tsi fwd 5speed, which i have been working on getting up to tip top shape. for the record i am very mechanicly inclined.
the ?'s i have for you fellow flipup body styled talon owners is on the front factory lighting. The last owner had alot of neons,,led's,, and other non factory lighting instailed on the vehical, and also had alot of the factory wirering changed. I know that the front parking and signal lighting is not wired the factory way, and im trying to figure out exsactly how in factory form the lighting should work.
ill start with the front turn lights, the ones directly up front, touching the little grill . i see they use due filiment bulbs, however there's only 2 wires going to them when it looks like there designed to have 3, and hence the lights do not light when you turn on the parking lights. they only come on and blink with the turn signal/hazard. im almost positive they are to light with the parking lights, and blink with the turn lights, correct?
also,, the side marker lights. each side marker light has 2 smalle lights in it. both single filiment. how are these suposta operate in factoy form??
the y way there wired on mine is they both come on with the parking lights, and stay on. and neither of them blink with the turn signal's. im guessing this also is not correct for factory lighting. one other dsmer on here told me one is to light up to light the turn, when the turn signal is on,, and the other is to blink? is this correct?, im guessing the lights nearest the back in the front side markers are to blink with the turn signals, due to the factory ones being Yellow. even though i have added clear corners. (yes i know about using colored bulbs to be legal. however im going to contiue to use clear unless i get busted.
thanx for any help you guys can give!!
Isaac
Isaac
