2-0turbo
- 787
- 5
- Mar 13, 2002
Lynchburg,
Virginia
I just got my SAFC installed tonight. Viewing a logger, with your foot OFF the gas, the standard throttle position is 10%, right. The SAFC registers 0% without touching the gas. No problem.
The problem is the SAFC hits 100% thottle when the logger only shows 60%. So, subtracting off the 10% normal, the throttle only moves 50% but the SAFC shows that it moves 100%. If you view the voltages on the "ETC" screen, the voltage is scaled correctly and changes the entire time I am moving the gas pedal.
It shows 100% with the throttle pedal still off the floor a good bit and then continues to read 100% as I push it all the way to the floor. What gives? Do anyone elses SAFC do this? Has anyone ever checked? Have I done something wrong, or have some setting funny? Ideas? Thanks.
) with my pocketlogger....). No matter what I do to adjust the car type or sensor or anything it still reads half. I dont know WTF is up. Did you call apexi and ask for a new one. The rest of the functions work fine, and its really tuned pretty good right now, although it shows the wrong rpm, the setting inputs are still dead on. Maybe Ill call them tomorrow. Later,
