running wire from amp to battery
flowerz
Aug 25, 2002
I have a 92 lazer, trying to find a grommet or something to run the amp wires from inside the car to under the hood? any suggestion besides drilling a new hole. my car is a non turbo for those wondering..
a much easier solution...drill a hole in the passenger side floor board and run the wire through there and then up to the battery. just be sure to secure it tightly and use wire loom.
even easier than that is running them through the firewall next to the gas pedal. Requires no drilling and takes 2 seconds. Just look down there and you'll see the hole.
Thanks for all the ideas. Im installing everything this weekend so i will give it all a try. hell if something doesnt work i will try the next
