Build your own water injection system!
OK most of you know how great water injection can be when used in a turbocharged car! IF you do not understand the concept behind water injection please do some research. And most of you know the price of a good water injection system. Let me start of by saying that in NO way am I trying to say that other water injection systems are no good. If money is not an issue for you, then AQUAMIST water injection is the way to go HANDS down! With that said lets start to build your own water injection system. I have done all the hard work searching around for the best parts to use and finding out what works well and what does not work well.
IF your like me and others and love to build, think and create stuff on your own then this is a great relatively cheap project for you. I will start of with the wiring part of the system! Wiring is the most time consuming part if the install. As you are wiring make sure you have good solid connections. This will make life a lot easier when you go to test the kit. Every time you make a connection test to see if it works. The wiring is pretty straightforward.
