98TsiAWD
DSM Wiseman
- 2,861
- 8
- May 19, 2002
94 3000GT VR-4,
North Dakota
Engine
90 6 bolt block/crank
95 pistons on 1g rods
Clevite Main and Rod Bearings
New Mitsu Oil Pickup
Mitsu Timing Belt Kit
FFWD Connection BS Elim. Kit (Uses OEM mitsu parts)
Topline Engine Gasket Kit
Cometic HeadGasket
93 Head
HKS 272 Cams
Fidanza Blue Cam Gears
Crower Valve Spring and Retainer Kit
SS Valves
ARP Rod/Main/Head Bolts
New Water Pump
3g Lifters
New 2g Knock Sensor
90 Oil Filter Housing and External Oil Cooler
Magnetic Oil Drain Plug
Turbo/Intake
AGP 50 Trim Turbo Kit (SPF Manifold, Tial 38mm Wastegate, Stage 3/.48AR.
AGP "Race" FMIC kit setup for gm mas
3" GM MAS w Translator (blowthru, upper ic pipe)
Magnus Intake Manifold
Exh Manifold,O2 housing, dump tube, and exh housing coated with JETHOT 2000.
HKS BOV (vented)
New T. Body Seals
New Exhaust Manifold Stud Kit
3" Intake Pipe
Driveline
TRE Spool
Fully Built TRE Tranny
16x8" Forgeline Competitions, 16lbs each, 245/50ZR16 Rubber
Raceconcepts Slotted/Dimple Drilled rotors
Axxis Metalmaster Pads
ACT Flywheel
ACT 2600
OEM TOB and New Retaining clip
Taboo Clutch Fork/Pivot ball
New Xcase Seals
New Front CV Boots
B&M Short Shifter
Shifter Base Bushings
Magnetic Tranny Drain Plug
Underhood Shifter Cable Bushings
Misc
RNR 3" Standard SS Turboback Exhaust
Slimline Fans
Fluidyne Radiator
DSMlink V2
850cc FIC Injectors
Walbro 255lph High pressure FP
AFPR from www.fullthrottlespeed.com
-6AN SS Fuel Line
Magnecor 8.5mm Wires
RRE Catch Can
NGK BPR7ES plugs (3 sets)
Fuel Pressure Guage (on AFPR)
No A/C, P/S, or Cruise
97+ Talon Front bumper
Autometer Ultra-Lite -30 to +30 boost guage
Ultralite Oil pressure guage
Ultralite EGT Guage w TRE Probe
RRE Lower Stress Bar
Front and Rear Strut Bars
Tokico Blue Shocks
I THINK thats it, anything else you can think of that I should buy and put on, or any OEM parts I should replace while the motor and everything is still apart would be great.
Cometic HeadGasket
93 Head
HKS 272 Cams
SS Valves
New Water Pump
3g Lifters
New 2g Knock Sensor
Turbo/Intake
HKS BOV (vented)
New T. Body Seals
3" Intake Pipe
Driveline
TRE Spool
ACT Flywheel
ACT 2600
New Xcase Seals
New Front CV Boots
B&M Short Shifter
Misc
Slimline Fans
Fluidyne Radiator
DSMlink V2
850cc FIC Injectors
-6AN SS Fuel Line
RRE Catch Can
Tokico Blue Shocks
