will bigger injectors and ecu help?
From what I hear, you wont get any horsepower. You'd just run to thick of a air and fuel mixture. So I hear. I dunno. I'm still learning. Someone correct me if I'm wrong.
~Andrew~:laser:
Bigger Injectors with a turbo ecu would make your car run worse. You only upgrade to bigger injectors if your maxing out the duty cycle of your current injectors and they can't supply enough fuel. so unless your making enough power to use up all the fuel your injectors can supply, you don't need bigger injectors.
