second gear grind
oneoffconcepts
Oct 25, 2003
I just got my 92 talon. It hadn't been drivin for a year year or so. When I go to shift into second it grinds in alittle, also it ginds when i go from reverse to first. It onlys grinds when the engine is really in motion (rpm). Also the pedal has about one to two inches of play. Is there any way I can tighted the pedal down, or is it most lkely a bent fork or something. I really think that if I get the play down that the grinds will go away. My crx did the same thing and when I tighted the pedal (leasend the play) it stopped the grind.
Also my steering wheel is 1/4 off set. The car itself doesnt pull or anything and it still feels tight in the steering. Just wondering if I can adjust it or if I put a new wheel in there will it sit right or be off also.
my comp messed up (actually my keyboard) and ended up sending it several times, but I didnt know it was in the general forum.
people in this neck of the woods only know about bodykits and such. off to general dsm discussion you go.
