noise on drivers side while driving
Steele Eclipse
Oct 3, 2002
Omaha, Nebraska
i here a clunking/ grinding noise on what seems to be my drivers side front of my car. the repetition of the noise increases with whell speed so i dont think its tranny or transfer case. i can feel the vibration through the floor of the car and i can hear it as well. it seems to go away in a left hand curve but seems to get worse in a right hand curve. its always present while going straight. it doesnt go away while pressing the brakes. it seems to be getting a little worse so any thoughts would really be appreciated. thanks. From reading on the forums, I am guessing it's the Wheel bearing, what does that usually cost to get fixed, how bad is that type of thing?
:dsm: Steele:dsm:
Check your crankshaft pulley to see if it's come apart. The rubber dampener material between the inner and outer rings can seperate.
