View Single Post
Old 10-01-2003, 06:54 AM   #3 (permalink)
sqhopeful
Proven Member
Classifieds Rating: (0)
Reputation: sqhopeful is an unknown
the ecu uses the o2 TRIM to help set the other trims as far as i know it. Also, keep in mind, the ecu ignores the trims for WOT so that is nto a factor here. From your trims you posted everything looks pretty good. all cars are different but the ecu take it's good'ol time adjusting the trims, in my car we are talking a day or so. To set the trims i had to make adjustments and check it in a couple of days.
My low trim is still acting up, it peggs at 140% at idle. but the 02 trim looks great boucing between 95% and 105%, if i let it sit idleing long enough it will fall down to something reasonable, but as soon i come to a stop again it's back at 130%+. ever run into this?
Offline
[posts] Reply With Quote
Sponsored Links
