Can this crack be overlooked? (pic)
91TSi FWD
617
3
Jan 26, 2003
Edmonton,
Just wondering if this crack in my turbine housing is bad enough that it should be replaced, or can it be overlooked? Thanks in advance.
attachment.php
I've seen many poople saying to overlook it. But that crack seems large. I personally would replace the housing just to be safe. Like to a 7cm housing (16g housing). ...and you'll have a poor-man's 16g. :D That's what I'm doing with mine.
I'll probably sell my stock housing, but that could be months from now. I'm pretty sure mine's in very good condition. (Not even 79,000 miles on it.)
Who knows if it'll crack further under heat and vibrations from hitting potholes. Better safe than sorry.
Matt, I would not worry about the crack and I wouldn't take aovsi's advice. Swapping the turbine housing to a 7CM won't give you a poor-man's 16G. What it will give you is a poor performing 14B. Have you ever tried this? I know of people that swap a 16G cold side on a 14B hotside for great spool (autocross turbo). I don't think you would gain much going the other way around.
Don't worry about the crack.
