which spark plug to use?
rayden
137
Apr 15, 2002
ok by motor is getting back togther. I was wandering what spark plug to go with. i have a fp big16g. i am not going to be running more than 15psi of boost due to factory fuel system. i have been told just to go with the stock plugs for now and see how they work. nothing major because it will be running low boost. this wont be for very long so maybe i should go with something better to keep from buying 2 sets up plugs. plugs are cheap so im not that worried about it. what do u all suggest.
Get the NGK 7's... i have the same turbo set-up.. run the cooler plugs.. I dont think you'll end up staying at 15 psi for long ;)
